FID RACING - Dragon Hammer Voltz
FID Racing DH
Reading the Rules!
shen zhen City ,China
Dragon hammer voltz
DRAGON HAMMER VOLTZ (2X70KG SERVOS,8S ESC, 680KV MOTOR)
SPECIFICATIONS
Specification:
Wheelbase:620mm
Tire track:465mm
Max speed:90km/h (8S)
Main chassis: 5mm 6061-T6
Esc Power Rating 300A: 8S Lipo
The main chassis height: 120mm
Servo Steering Power : 140kg (2x 70kg servos)
Battery box size: 190x75mm
Mud Terrain Tyres: 230x85mm
VoltZ Main Chassis:
5mm Thick Milled Alloy Chassis 6061-T6
Dual Steering Servo Set-Up 2x 70kg servos (140kg Combined)
Independent Front Shock Absorbers
Large Capacity Shock Absorebers: 235mm Rear 185.5mm Front
7mm Thick Shock Shafts
Four Link Rear Trailing Arm Suspension System
Billet Alloy CNC Machined Rear Axle
Billet Alloy CNC Machined Trailing Arms
Billet Alloy Upper Four Link Ends With Rose Joint Ends
Billet Alloy Fourlink chassis mounts
Front/Middle/Rear Differentials, With Billet Alloy Diff Cases
Rear Mounted 74/120 Brushless Motor
8S 300A ESC & Brushless Motor System
High Capacity Battery Box (8S /12S Lipo Battery Capability)
Voltz Electrical System :
ZTW 300A ESC,
Motor:680KV 34000 Max RPM,74/120 Brushless motor
8S Lipo Battery Capability
Built in Cooling System
ESC fixing plate(3MM) :reserve insert position for hobbywing 200A ESC
Dragon hammer Voltz 4WD drive System
Internal rear drive shafts,12mm
Helical cut front & rear differential crown & pinion gears
Rear Telescopic Centre CVD Driveshaft,25mm External
Front CVD Driveshaft,20mm external
Middle differential réversible System
Body shell
CLEAR, With 2 Full Livery Sticker Sheets
Yeah...same model. It didn't have the cage, body or wheels on it though. A guy brought it in to the LHS to get it the ESC set up...
It's heavy as F*** too...don't know if thats a good thing or a bad thing but the stock truck is billet aluminium everything.
It kind of made the Vekta look like a toy.
The wheel hubs are similar to the IRP wheel hubs but the FID uses 5 screws instead of 4.
Tooling marks on the rear axle look way better in person than they do in a picture.
I'm kind of pissed i only took 1 picture of it now.....
I probably wont see another one in person again....
One thing that did catch my eye under all that aluminum....
It has a dual servo setup for steering....it user those JX 1/5 scale servos but the lay flat...one in front of the other...I didn't get pics of it though.
Hi
Im new to this forum and just wanted to share my thoughts on the voltz.
I bought the Voltz in february and have done quite a lot of running with it. Generally very satisfyed with the car even if there are some weak spots. Been running mostly sand tracks but also some bash running.
Here is my last bash run.
How long of a run can you get? What S and mah are you running?
It depends on track condition and temp. In
On 8S 15k mah 15 min runtime is typical on offroad track. A bit longer on most bash spots(not as much start-stop running).
8S is plenty power with the 70mmx120 stock motor... have tried lower s but that makes on sense since it is soft enough in the throttle curve on 8.
I burnt an identical esc in another 1/5scale on 12S so i don't dare to try that in the dragon.
Ouch! are they expensive???
That depends. Car, lipos and motor survived so it could have been much worse. But the esc was toast and that is about 4000SEK= about 400 dollars.
Probable cause was a rock or maybe the brake disks jamming the drivetrain when I tried to reverse. That overloaded the ESC so it shorted and the battery connectors melted(the gray smoke in video) .
On 8S things like this don't seem to be an issue.
Suggestion put a 30.5 ect (gas motor) has no esc problem solved ??????
True. But this car and also my other 1/5 electric have done a lot of running the last year and proven to be very reliable on 8s. A gasser is not more reliable. Then there is the weight of the Dragon. It is a 24-25 kg car with 230mm wheels. That car NEEDS a large cc motor to be fun. I have driven the petrol version w stock 36cc engina and that is really underpowerd...
30.5cc is good in a baja but not in this behemoth
Yes it goes well. But it has smaller wheels and probably is not geared for more than50 kph. The mcd in the clip has a top speed w track gearing of 68 mph (video). Impossible on track with big understeer issues and ztw esc has not good throttle curve on 12s. 8s is like a really good gasser .
3 vids. 1 dragonhammer and my brushless mcd buggy both with ztw esc
2speedrun 70 mph
3 crawling on 8s
Just a few more close up pictures of the beast...
