what 2 stroke oils do u guys run?
Z.hb71
Build Thread Contributor
im curious because im switching back to gasoline as ive said. klotz isn't available nearby, sooooo I want to see what others run just to see if your oil is local. my options are motul 510, max 927, castrol rstts, maxima premium, motorex forumla
Others here most likely run high quality 2 stroke oil!.....
Castor 927 is highly recommended by OBR, but I'm just running Havoline tc-w3. Been on the same bottle for a while now, and haven't had any issues. Not sure if there's an inordinate amount of carbon build up, but I can take a look later if you want.
if you can id appreciate it.
I run klotz super techniplate. You can order it by the gallon off Amazon. It has bean oil (caster) in it, plus the added benefit of being synthetic and it's very shelf stable. It was good enough for our race boat donuts good enough for everything else. Plus I like how it smells.
Motul 800 Grand Prix 2 stroke kart oil, Klotz is good but some do not like dirtiness of it. But protects bottom end rod bearing if you spinning it 18,000 + all the time. Amsoil has sabre professional also
