- 27,691
Reason im asking is, my case case mini holes drilled into it instead of a big gaping hole like a normal cy/zen case. So rocks can't get in but should I still do it? Tell me what y think
Like mine ???I wouldn’t. Those holes are tiny af
Clone pull starts have a tone of grease. Thet can seize fast?? happens to me more than once....now I only want the zen ones??I think from what I learned this past summer is the mesh mod is purely based upon driving conditions. If you think (or already know) that you will be bashing on wet grass / wet mud / than I think the mesh mod makes sense. This past summer I bashed mainly in dry conditions both grass and dirt and I had zero issues with debris clogging the air circulation vents. (however I also make sure I have the removable Rovan dirt guards in place). I did have that issue where fine sand dust seized the pull start camming pawls and caused pull start issues, but even if I had the "mesh mod" it would not have done me any good. The mesh mod will not keep out fine dust debris.
Learned this after going through about 4 clones in 2 weeks now I go through 1 zen every 2 months or soClone pull starts have a tone of grease. Thet can seize fast?? happens to me more than once....now I only want the zen ones??
??? what the heck y doing son?Learned this after going through about 4 clones in 2 weeks now I go through 1 zen every 2 months or so
Haha inexperience mixed with poopy equipment??? what the heck y doing son????
Que the vid of of you sounding like you about to cry ??Yes I also learned bout the clone gear.... you land up buying ×2 or ×3 compared to the real original parts?
Teddy bear douggy needed a hug n a pat on the back ???Yip pretty pissed in that vid??????
