Z's HPI Baja 5b/5t build
Status
Not open for further replies.
Came a day early. These are the Zoni axles. They are zinc coated hardened steel. They were $24 so I am a bit skeptical, but we will give them a test and see how they do ?
With the springs off ,I usually pump them up ,an keep the rod at the top end ,an then crack the cap open a little to
relieve any air ,an then close the cap off ,I do this twice ,an leave it at that!
Then after that ,I pump it ,an if the rod pushes down on its own ,then they should be good to go!...:cool:
Status
