I wouldnt do that, when the fluid warms up it will expand some. It needs somewhere to go, or by by seals
Definitely buy seal! ? when I did my last baja diff I put 300k fill it in the one half quite a bit then just closed it all up ?? 300k more like jelly than oil???or by by seals
500k is crazy thick ? using 60k as recommended by obr in this 1 ?Definitely buy seal! ? when I did my last baja diff I put 300k fill it in the one half quite a bit then just closed it all up ?? 300k more like jelly than oil???
Yyyd ?We will see ??Oh look I think I saw this post somewhere else ?. Hope they work out for you Z
Yep Im just lazy ?Easy to fix?just do up the turn buckles got the out you caliper make sure both are the same??
And they are in ?
Yes I know my camber settings are totally fekd, need to figure that out some day
Yeah was kinda struggling there ??Coming along nicely. The brakes install was kind of hard to watch. Surprised you didn't edit to make it look like you got it on the first try.
nnidgaftbh?If anyone gives a fek, here's the transmission assembly vids ?
Priceless ??????nnidgaftbh?
