KevTrem
I use 6S softcase batteries in my Tamco, a couple of them are massive 10000mah units from UAV's that I was given with the car. I've since made my own battery tray that is flat base and uses 3 velcro (hook and loop) straps, 1 length ways and 2 across the battery. I've rolled, end over end and cartwheeled the hell out of it, landed flat from 8ft jumps and i'll be honest the battery has been the least of my concerns. If you can stop it moving about then it wont wear through the protective plastic wrap. Other than that not much else you can do.
