20:1??Everyone is Gunna be different and it's a matter of preference. I run 20:1 with Klotz supertechniplate oil
Foul plugs often?Nope, Definitely 20:1 .
No. I just run it because that's what I had mixed for the 70cc, so it's left overs. If it gives me problems in the future I'll lean out the gas and oil mix (like 28:1)Foul plugs often?
| 28:1 in my 4x? | |||
Yes?Gotta highjack the thread a bit, do you have to retune if you switch oil ratio? Like for say 20:1 and you switch to 28:1
Figured so ?Yes?
Check if you have any local hobby stores. Having the right oil and wieghts Definately help. Team ascociated does some that local hobby stores carry often.Carb settings were about a half turn off for both high and low. I set them at stock settings it fired up. Had to ccw the low needle a quarter turn. Its idling great. Going to do a cpl heat cycles first since its nasty out with rain. Supposed to rain tomorrow too... can I buy diff and shock oil at a local store anywhere? If not I'll have to order it online and wait. Was going to take it apart and add the proper oils to shocks and diff while it's raining tomorrow.
