Lets talk real gas mixtures and oils
TheRipper
I know what's recommended, I'm curious if anyone thinks or runs otherwise? And different oils different mixtures?
I just assume some peeps are running more lean. Just curious how lean. I've never ran redline. But I've heard good things about it.
Carb settings were about a half turn off for both high and low. I set them at stock settings it fired up. Had to ccw the low needle a quarter turn. Its idling great. Going to do a cpl heat cycles first since its nasty out with rain. Supposed to rain tomorrow too... can I buy diff and shock oil at a local store anywhere? If not I'll have to order it online and wait. Was going to take it apart and add the proper oils to shocks and diff while it's raining tomorrow.
Check if you have any local hobby stores. Having the right oil and wieghts Definately help. Team ascociated does some that local hobby stores carry often.
If I remember right the stock shock weights for the Baja is 5wt in the rear and 40 in the front, with 5k Diff oil. Could be wrong ,someone correct me
