nymike
- 35
- Thread starter
- #21
The stock Spektrum 901 is a god awful servo. Even with conservative EPA's, it still burned up in no time. Exactly as you described. The servo would just become weaker and weaker until it just barely steered. It was noticeably hot once the servo fade was apparent. Just upgrade the servo, it's not up to the job. It lasted all of 3 days for me before I sold it. After it cooled down, seemed to work as normal but it's not correctly spec'd for that vehicle. You can forget running in the grass, it barely holds up on tarmac.
Sean is right though. I find nobody I know uses EPA's. they are very important when it comes to preserving your servos. Unfortunately, EPA's weren't the issue with the Spektrum servos.
so should i swap out battery, servos, receiver and remote? good time to get everything straightened out?
