"Also, whats stopping me from using this stuffed crank in new g320?"
Totally different internals,Completely new bigger cranks.
C.Y. + Zens flywheel are interchangeable on 23-30.5.
There's no 320 CY.
Interchangeable parts between- Zenoah, CY & HY engines:
- clutch plate, shoes and spring
- carbs
- flywheel
- pull start
- exhaust
- spark plug and coil
I'm looking for a +2mm crank possibly,if it's in good condition.
I run FG rc's so smaller engines are better-2wd light cars.
(I'm thinking of putting a 320 in one anyway - ??)
I have a 29cc 4bolt engine that had the same damage.
There's a post on here about it:
"Can I save it".
I bought new case + piston/ring etc. I might just try to use head since it had good compression or
I might just get a new head and attempt porting using damaged head as template.
I have a 2bolt upgraded 23cc > 26cc ported head,that runs like a champ.
I think 2bolts can't handle much above that reliably,but there's always exceptions.
I have ZEN,CY & OBR engines.
