John Parks
Print my own
- 9,680
- Thread starter
- #61
Got it 99% finished. Setting up dual servos fekking blows! Mostly because it's the first time I've had to lol.
I used a Y harness adjusted the linkage for no buzzing and voila all good for years??
I hate doing channel mixing on the radio, it's such a pain....?
Yes that's where I was? the center was not the same on both?? so I adjusted each one till I was 99% same the tweaked the end points on both so there was no binding??If both servos were lined up perfect that would work, but they are not.
I unfortunately haven't done mixing on my futaba, just my gt3c.... I assume it's a bit different, as Im not running flysky programming in my radio. But I have this that may be helpfulIf both servos were lined up perfect that would work, but they are not.
Do you run a futaba? If so, I could use some hwlp
So been doing some reading up on the 7px, EDIT. Ok found it. Page 123 in the manual. Program composite adjustment.
Mode 2 to master and slave a channel. Set steering as master, and pick whatever open channel you have to slave to steering. There is independent EPA, and trim functions. Should fix you up with a bit of fiddling.
Channel 3 is the slave of the steering servo
Maybe you should get a set of the mtxl servo horns ?? the one is adjustable ??![]()
Did you try adjusting EPA and trims, outside of the master/slave setting?
