Losi 5ive-t (BB build)
If both servos were lined up perfect that would work, but they are not.
Do you run a futaba? If so, I could use some hwlp
I unfortunately haven't done mixing on my futaba, just my gt3c.... I assume it's a bit different, as Im not running flysky programming in my radio. But I have this that may be helpful
So been doing some reading up on the 7px, EDIT. Ok found it. Page 123 in the manual. Program composite adjustment.
Mode 2 to master and slave a channel. Set steering as master, and pick whatever open channel you have to slave to steering. There is independent EPA, and trim functions. Should fix you up with a bit of fiddling.
So I have one steering servo in channel 1, second steering servo in channel 3. Would the slave servo be the second steering servo in channel 3, or is the throttle servo the slave
Did you try adjusting EPA and trims, outside of the master/slave setting?
No idea. I messed with it for 2 hours almost with no luck. I read about 30 pages in the manual and still am not any further at understanding.
I ended up saying screw it, and took the easy way out. I adjusted the sub trims on them individually to get them lined up.
