- 22,962
Use that to fix tractor seats?
Have you seen it tried? They have many varieties now and some are rather flexible. Sure would be a hot mess though.If your talking about expanding foam it won't work but feel free to try for yourself and please film it if you do?
Nah I haven't but I've seen it done or rather the mess it made ?Have you seen it tried? They have many varieties now and some are rather flexible. Sure would be a hot mess though.
Definitely need to be careful. The poop grows a good bit. I bet if you could meter out the proper amount, and rotate the tire as it hardens, it would work. ?????Nah I haven't but I've seen it done or rather the mess it made ?
Using just a little bit of glue can go a long way too. I'd only use a little if you plan on owning those rims for a long time.I ended up getting 2 new yet different ones and played musical foams over a few different tire and wheel combos. It sucked.
Yeah you really don't have to but sometimes if you got this kind of issue it's good to glue the bead ring onto the tire itself. Helps loads and bead rings are usually dirt cheap unless you are running aluminum and by then your tire would rather shred then come loose.I gave up gluing wheels when I gave up 1/10 scale
