- Crafers South Australia
Sweating ? where you ???
Nah i wasn't careful at all.i figured, it's feked as it is, and carefully trying ain't gunna do poop, so I sent it with a bunch of hack tools and I got it. What I had to do was first, I tried drilling it with my bits, and heated the crap out of it, which got absolutely no where. Then , eventually, I took a carbide Dremel bit (the ones I used for hacking up the 70cc case) and went at it with that, that got the hardened steel bit out of the head , and then I just drilled it out. Re tapped it aswell.Sweating ? where you ???
Hey, it was hardened steel and totally stuck , was never gun scome out if I didn't do some redneck level hackery ????when removing a little screw makes you feel like a GOD ????????????????????????????
WTF speak English son??????was never gun scome out redneck god
Having English issues here mate, I've got wd40 on my figers ??????WTF speak English son??????
I've got sum pb blaster in the garage actually, I'm just a lazy bastard and forgot about it ?That's your first problem, get some PB blaster, or kroil.
figers??Having English issues here mate, I've got wd40 on my figers ??????
Yeah, grass is the problem so it definitely should keep the grass out. TheoreticallyAnything's better than nothing ?
?....well it may work ??It's Sewn on the ps housing so I don't think it's going anywhere ?
I present to you, chassis stiffener ?? wonder how this will work,
Yeah stock, that's probably flexing alot. That brace made don't move at all .might work for the time being?....well it may work ??
it may help if u had a decent lower rear engine brace?...look like u running stock one?
wtf did you expect ? it's Z were talking about ?? IDGAF really ifnit looks like ass, what works , works ? well see if this works.Franken rig 2.0????
