Z's HPI Baja 5b/5t build
Status
Not open for further replies.
Aight I went for a run, only lasted 10 mins ??‍♂️ recorded this time,gunna upload it tomorrow for y'all ? problem is, the servo is glitching. Not super crazy, but it's definitely a problem. Doesn't happen when the engine is off, only while running. It stuck at WOT at one point and I decided to call it quits. At the beginning of the run it was fine, but after some running it starting acting up, think it's getting it from the ignition on the motor.
Winter time just you wait ???? j/k
@crucialRC that was a joke, you know I don't have 90gt money ???
Check your plug cap or the the coil cable may have crack/split may causing interference ?
Man I don't think the rovan gave you this much crap.
That's because it didn't have an engine when I joined ?‍♂️?
I almost feel bad busting Z's balls about his always broken rig. Yet im again reminded of the tounge lashing the dbxl got. Just so you know Z, I ran again today, probably the 20th time in a row with no breaking.???
Just so you know, I don't care and go deep throat Losi some more why don't ya ?
Status
