Crucial Kraken Vekta.5
The harness gets its power directly from the battery, bypassing the rx. All the rx sends is the signal. Really this is all the rx needs to do, but for the sake of convenience you pick up your power and ground there too. This is good for a few reasons. You get less voltage drop going straight to source for your power, theres no fear of over loading the small circuitry in the rx from amperage spikes, cleaner signal from not having to deal with possible rf interference from the amperage damping up and down to make the servo(s) move. It's really a good deal. And it's simple to boot. Hook it up to your steering channel, get your servos in sync via the linkage/ adjustable horn, set EPA,trim and sub trim like normal for one servo. No messing with two channels. Now this is really only helpful on twin servo set ups that are slaved together. If you use a right/ left set up you wouldn't necessarily use this as you can set up steer braking, different angle bias depending on TX input, 4wheel steer, crab steer and the like. We just don't need all that in our rigs. Channel mixing can be a pain, look at what we just went through with the 7px to master slave a servo. Can it be done, yep, is it a pain for us who don't normally use these settings, yep. So the harness takes all the fuss out if it. Bit more expensive up front, but saves the anguish in the long run.... just think of what you may have to go through if your tx crapped out.
Well I have the bypass harness in now ffrc dual servo kit, and the Hilly 7010d servo in. Not sure why they don't include the instructions with the bypass harness but it is on the davesmotors.com item description. And I'll post it here too. I was barely able to get the battery box door closed with the damn harness in it. I had to strategically place every wire. @Haric I need that cnc'd batt box now bro?
20200626_153554.webpScreenshot_20200617-144004_Chrome.webpScreenshot_20200618-201113_Chrome.webp
What servo saver are you using for your dual setup?
Servo savor? All our rigs have built in savers in the bell crank under the top mount.
Decomps crap out a lot in my world. Have to keep a few extra on hand.
About how often. I now have 4 spares on hand. My symptoms of course was the oil splatter and she would fall on her face on throttle. And I noticed as the oil on the head got worst it would backfire a little on full throttle. All seems to be working good now??
View attachment 60770View attachment 60771View attachment 60772View attachment 60773View attachment 60774View attachment 60775
Until...
I thought something happened in the engine cause it just locked up. Im actually happy it was just the spring. Upgrade time now.
In the last year , C has surpassed Doug in being made of money ??
Doug's starting a new life, I'm well rooted?
Guess we're gonna change that sheriff to sherry...C,for President.?
