- Maryland, USA ??
Oh ok??Not gunna use wheels
Running off road so I don't think it's something I need .
You can use a rear chassis skid plate put on backwards Zee
Would 3mm be too weak?Ok so the people at target are trippin ballz, $15 for a feking cutting board . Gunna order some polypropylene or hdpe from amazon for much cheaper. What thickness should I be looking for ?
Holy FEK . Think that's overkill for me. Going to go 1/4 (6.35mm) probably.Tha bebop is 9mm
Yeah its pretty thick. That'll prob work as long as you brace it.Holy FEK . Think that's overkill for me. Going to go 1/4 (6.35mm) probably.
You've never seen a bebop wheelie bar huh? Similar meterial. Cutting board is just a sheet of plastic ?Wait you were gonna make a wheelie bar out of a cutting board
Yeah I'm going to have an aluminum peice going up to the original bumper thingy. Maybe I'll do a little 1/10 scale shock there if I want , so when I hit it, it doesn't fold the aluminum braceYeah its pretty thick. That'll prob work as long as you brace it.
He is prob thinking of a wood cutting board? All the bebop uses is a turnbuckle, no shock.You've never seen a bebop wheelie bar huh? Similar meterial. Cutting board is just a sheet of plastic ?
I'm aware of that. I don't think bigbores are jumping are crashing like I am though , that's why I was thinking about that idea.He is prob thinking of a wood cutting board? All the bebop uses is a turnbuckle, no shock.
A plastic one bud. Like this
Yeah fek that. I've seen too many vids of the blades exploding and hitting the person's eye or some poop. No thanksCant imagine zed with an angle grinder.... may cut off something he don't want to ?
