Crucial 5ive-T
Got a little more done today. ADI bellcrank installed✅, RCmax top brace installed✅, IRP steering links installed✅, and ALX S50 back home✅?
Everything fit perfectly??
With the adi bellcrank, I had to remove about 13mm of rod end and turnbuckle from the IRP steering links. A hacksaw made quick work and a clean cut of both pieces??
20200820_165802.webp20200820_165954.webp20200820_171456.webp20200820_175353.webp20200820_180316.webp
Pinion/spur meshed✅
Next up will be the wheels/tires, add wiring for the front bumper light, clean up wiring, mount the exhaust isolator, connect fuel lines, mount the tach, then braap!
Lmao glad I'm not the only one. 5mm my ass, not even close. I was about 8-10 on the rcmax build, and this green losi needs another 2mm ish.
Looks dam good though crucial, nice build. What did you send the 50 off for?
Thanks John. The S50 been sitting on my table. Didn't send it off. Just back home in the Losi. Bad choice of words?
Damn another really nice build (y)
You and John are making me want to start looking around for something big bore sheeesh thanks a lot guys
Do it!
Ah I'm in love..... lance you select me the wrong parts ?????
Hey I almost made a hybrid with those parts?
I'm trying to make the led bar turn off but it won't. Its on ch4 and I have ch4 on sw1 but when I press the button it just stays on. I have the futaba 4pm. Any ideas?
Do it!
Depends on lightbar. Some need the turnigy 14v battery for them to run
Ok figured it out. You need a light controller. The reciever has 3 pins power ground and signal. Guess what all your doing is giving the light power and ground. Theres nothing for the rx to tell (switch) to turn on or off.
Ahh, makes sense. Light bar only has 2 pins for power and ground. Thanks Sean??
