Haric’s Carbon fiber panels
@Z.hb71 ive been watching videos on YouTube and there are a couple different methods of doing it. There’s a vacuum infusion , and just a regular way which is using the brush and applying epoxy. That’s the method that I will be doing. Once I get it down I will be buying the other equipment for vacuum infusion??
Yeah the brushing method is what I've seen ? tell us how it goes/how easy or hard it is to do ?
Can I buy the first ones for a losi ?
Also custom set for my outlaw ??
The time that goes into it and materials costs won't be worth the effort. You can't get a smooth finish brushing on epoxy and you'd have to do multiple layers of carbon cloth to get any decent strength. I know from experience! I did an experiment making the little side plates on my Losi 5T with carbon cloth. I did 6 layers of cloth with resin and let it set between two flat plates with pressure. Even with 6 layers it was very flimsy. I ended up doing 6 layers of carbon with 2 layers of fiberglass mat. With all the hand sanding I had to do to get a nice flat finish was way too labor intensive. I had the intention of selling sets because they would be easy to make. WRONG! I did one set and that's all I ever made.
Good luck though!
