so do i...lefty lucy?..and righty rachI'll pass, I have a pipe polisher at home
they take it in turns?
Thats what I'm talking about ????Im all about homemade stuff. Screw that way overpriced axis stand. As a fellow spinny chair rc wrencher, I approve.
thanks but i don't want another hostile plastic spur, seeing as though i have had great luck with them........NOTKnew I had some, I got 17/57 and 18/56 combos, you interested Zee?
you also cant be bothered to run your rigs ??It's not the spurs it's your rig.
As you can see the hostile spur I have is used and in perfect working order?
But I have been running my rigs and they don't chew spursyou also cant be bothered to run your rigs ??
you said bearings, i have checked and every bearing feels like new with zero playI can tell you what you problem is but you wouldn't listen
I rest my case, crack on kid?you said bearings, i have checked and every bearing feels like new with zero play
think im pushin too much powaaaaaaI rest my case, crack on kid?
Exactly your bearings are dry?im still sticking to the fact that there was oil in the clutch system from the leaky ass bearing seals. now there is no oil
theres a lil bit of luubeExactly your bearings are dry?
I doubt it's that one, I mean it won't hurt to change it though if it's that oldcould it be the gear plate/bearing carrier? still running the stock ones
