Wt-929 carb trouble
ChrisBlue233
Hello All,
I was suggested a WT-929 carb over my stock one because I wanted smoother acceleration and idle. I got it in the mail from a friend and I see it doesn’t have a choke or a primer bulb and it only has one fuel fitting. Does this carb pull up fuel or does it have to be gravity fed? I’m going to have to tee my fuel lines before my inline fuel filter because I have a supply and return hose and I just can’t leave one hose disconnected. Would that be the correct way to do it? Can’t seem to find a fuel tank grommet with just one hole. I tried to plug the return fuel line but it wouldn’t start because it wasn’t pulling up fuel to the carb. Either I’m doing something wrong or I just need to tee them together as there is a leak.
Hello All,
It only has one feed And no return and it will pull fuel by itself. Block the return hole in the grommet with a screw. Putting a bag or something over the air filter and that will act as a choke, do a fuel slow pulls (4-5) and it should suck fuel. Then a few fast pulls and see if it starts. I would've stayed with a normal choked carb but that's me ?‍♂️
Those carbs are mostly for boats, where you don't have an air filter and can block the intake with your hand to use as a choke.
It only has one feed and it will pull fuel by itself. Block the return hole in the grommet with a screw. Putting a bag or something over the air filter and that will act as a choke, do a fuel slow pulls (4-5) and it should suck fuel. Then a few fast pulls and see if it starts. I would've stayed with a normal choked carb but that's me ?‍♂️
It has no return ? I had these on my twin?? personally don't like them .....no choke no prime???‍♂️
