ChrisBlue233
Hello All,
I was suggested a WT-929 carb over my stock one because I wanted smoother acceleration and idle. I got it in the mail from a friend and I see it doesn’t have a choke or a primer bulb and it only has one fuel fitting. Does this carb pull up fuel or does it have to be gravity fed? I’m going to have to tee my fuel lines before my inline fuel filter because I have a supply and return hose and I just can’t leave one hose disconnected. Would that be the correct way to do it? Can’t seem to find a fuel tank grommet with just one hole. I tried to plug the return fuel line but it wouldn’t start because it wasn’t pulling up fuel to the carb. Either I’m doing something wrong or I just need to tee them together as there is a leak.
