Stock 20t engine mounts
xenogears
Fairfax, Virginia
I can’t get a g320 mounted on the chassis using the stock 20t mounts. Is there some trick to this that I’m not seeing?
My problem is with the two holes on the fan cover side, I can’t see how to get the 20t mounts on that side even when all other mounting screws (top and bottom of clutch housing) are not on.
Hmm, I ordered mines from ddm and selected the 5ive setup. Clutch housing fits great, but the fan cover obviously not so great.
Really wanted to break this thing in tomorrow. I have a 22t pinion and engine mounts that are for a 5ivet 2.0, I’m thinking maybe those would fit since 2.0 comes stock with zenoah and also assuming pinion spur size and spacing are identical between the two rigs :unsure: Will give it a try.
When I ordered I got the fan cover right but I missed the clutch plate thing??‍♂️ the 5b also needs a cy plate other wise it sticks out too far?? i would stick with a 21 pinion? 22 is too tall lose to much bottom end? the spacers are all the same??
Did a bit of experimenting, here’s what will work using the stock zenoah fan cover and what I have on hand:
stock 20t pinion, all stock 20t engine mounts except for fan cover where to keep it centered I’d have to reverse one 20t mount for one hole and use a 22t on the other. Fits perfectly!3852DF68-0AA6-46CF-A515-100E80050652.webpD72CE1D5-82AE-4A6C-AD37-08903C3FC647.webp
