DBXL DBXL revving but moving slow
GdotC
Any idea what could be the issue with DBXL moving slowly when revving it up all the way? Any suggestions on what to check?
when I give it gas, the engine will rev up like normal, butit will only move slow
So I finally had a change to take a look and i think a pin from the front part of the drive shaft popped out. If this is correct, where can I find the pins to replace it?
Thank you all for all the input and suggestions.C130B185-E598-495A-9D36-BC52A0E1F9A5.webp
