How lard ?‍🤔 is your car?
DougStar
Well Known Member
PLUS member
Build Thread Contributor
Crafers South Australia
Got my collection on a bathroom ? scale ⚖ and the results where quite surprising ? (all with ½ a tank or less)
Twin 18kg or 39.68lb
Sx5 15.8kg or 34.8lb
L5B 16.6kg or 36.59lb
Sbaja 11.8kg or 26lb
Fg 12kg or 26.45lb ( had to hold it in a box? as its very sick and need a rebuild)
So what dose your car weigh ??
my dragon hammer twin was just shy of 22kg , but since been on a diet , still not finished it but will reweigh when done,
blue roofchopper shorty rail is around the 14kg mark,
orange rail is around the 16kg mark,
all with empty tanks,
my fg stadium i have no idea cos its in bits in a box and needs a rebuild,
my other baja is the same as the fg (y):ROFLMAO:,
also have enough parts to build another 1 or 2 bajas as well,
axial yeti xl is around the 5kg mark with batteries,
edit, two with fg's and both in boxes, seems to be a theme starting :ROFLMAO:
My Baja weighted 25 lbs (pre rebuild) ?
So you saying my beater/ bits baja Is heavier than your car ? my car 96% stock ( v1 dominator and an alloy bell carrier) .......figured it out? you must be missing parts? that would explain the constant break downs????
I will through mine on the scales in the morning, I always thought my Baja was about 15kg with the steel cage and other extra's on, thought the Truck was about 20/25kg
