- 22,962
Get a carbide bit and drill the axles out. don't muck about with the smaller pins. Just will give more shite.All wheels on.
Drove it with 16T pinion and on the 2nd day, the front 5mm hinge pin ripped out sending the wheel sailing...
So I’m looking for Titanium 5mm hinge pins to go in the front wheel axle OR I may use the thicker hinge pins from a Lost 5T and possibly drill out the stock axle to accommodate them. The IRP hub adapters accommodate both 5mm and slightly larger pins.
