Crucial Kraken Vekta.5
You can order them either way. But typically most 3" are a 1 offset and most 2" are a 0 offset.
Easy way to tell though is if the center of the hub is in the middle of the wheel it's a 0 offset, if the hub is off center it will have a 1" offset.
I got the 1 inch offset the regular version. Do I need the extended adapter or just the regular one?
With the 1" offset the wheels are getting pushed in 1" so if I want to be same width as stock should I get the extended ones?
The standard adaptors will put it around factory width, even a touch wider I believe. The extended adaptors really push the wheels out far, they look odd, and awful with the extenders but that is my opinion
