- 27,691
I like the long videos, mainly cuz I'm bored and have no life ?
I try to keep em around the 10-12 min mark.I like the long videos, mainly cuz I'm bored and have no life ??
Ok ok so I’m not the only one ?I like the long videos, mainly cuz I'm bored and have no life ??
Thanks bro?? I put out vids for the people???I skip the Intro on the people who put vids out on a regular basis!..
Crucial always puts out good vids ,so I watch every bit of it!...![]()
You can't choose your offset as far as I know of.
You can order them either way. But typically most 3" are a 1 offset and most 2" are a 0 offset.You can't choose your offset as far as I know of.
He has the upgraded shaft in his videoHey lance, can you check and see how your driveshaft lines up, if the yokes are lined up?
Easy way to tell though is if the center of the hub is in the middle of the wheel it's a 0 offset, if the hub is off center it will have a 1" offset.
I got the 1 inch offset the regular version. Do I need the extended adapter or just the regular one?
You can use either adaptors, if you want an extra wide stance get the extended.
The standard adaptors will put it around factory width, even a touch wider I believe. The extended adaptors really push the wheels out far, they look odd, and awful with the extenders but that is my opinionWith the 1" offset the wheels are getting pushed in 1" so if I want to be same width as stock should I get the extended ones?
Great thanks for your help.The standard adaptors will put it around factory width, even a touch wider I believe. The extended adaptors really push the wheels out far, they look odd, and awful with the extenders but that is my opinion
Mine are lined up or pretty close. I can get a pic after work if you need one.Hey lance, can you check and see how your driveshaft lines up, if the yokes are lined up?
It's good mate, I'm gonna break the welder out on mine I think. Thanks.Mine are lined up or pretty close. I can get a pic after work if you need one.
?Welder? What did I miss? I've been MIA lately. Work is killing me?It's good mate, I'm gonna break the welder out on mine I think. Thanks.
