- Thread starter
- #241
Good idea.I had contemplated about sticking a radiator fan on the side of one of these one day if I ever get one because I heard heat is an issue if you like to bash for long times.
What are you guys getting on a full tank? I am only getting about 10min a tank? Is this normal for big bores?
That doesn't necessarily work. Some times it take more torque to loosen something than it took to tighten it down. Also if loctite was used then it will definitely take more torque to loosen it.lol see how much torque it takes to break loose a tight one![]()
That wasn't very responsible now was it. Why would you do a speed run on a road where there is traffic?Little off topic but wanted to take the vekta out but I was kind of lazy to carry it so I said let's do some speed runs with the typhon.
Well, crashed at 120mph into a moving truck
rear tire. Broken carbon fiber shock tower, hing pin, upper lower control arm and bent wheels. Chassis is fine.
I was running in middle of the road with cars behind me stopped collecting my spindle, wheel, shock and battery. Should of got on camera. What a crash I tell you.
It was a joke btw
Wow, you really crashed bad, was there an argument with the guy you hit
Was your Typhon stretched? I do understand about finding places to run . I'm still hunting for good spots for the Limitless.No traffic on this road only bunch of manufacturing companies. It was late afternoon and this guy pull out from a parking lot and as soon as my car passes me I turn my head his right in front me.
You right not a good idea to run on public road but you know how hard is it to find a decent smooth road.
Anyways , best I got on 6s is 120mph with 34P and 29 spool. Maybe I need to run a cap pack but I am going to go 8s anyways so will see if I can hit 140.
No he didn't even stop.
If your low speed needle is way rich it do this.Anyone else has the idle screw all the way in on the 990 carb so the car can idle probably? I asked rcmax on messenger and he said is normal..
you mean yer vekta niz ?i'd say either a broken bell or yer clutch perch is spinning on the crank, loose bolt and popped off the taper a tad,So before I tear this thing down I like to get someone's opinion. Took th car to the park and ran it for maybe 5min and all of the sudden the car didn't move. Engine runs fine. When I hit the throttle the car doesn't go anywhere and sounds like is performing a 2 step ???
Checked the axles and drive shaft everything is fine. Diffs are fine also.
So I am thinking something in the tranny let go?
