Polar_Bus
- 1,549
So I stated taking this apart what's this servo on the bottom for next to the steering is that for reverse?View attachment 82324View attachment 82326View attachment 82327View attachment 82328View attachment 82325
So this truck had reverse motor is super tight need to inspect and see if it was run hot or never broken in can’t turn flywheel unless I use pliers
Nitro engines when let sit for years are almost guaranteed to internally rust and seize unless they were literally drowned in after-run oil ( which almost nobody does) and at that point they are junk. Those WERKS racing clutches were awesome. A very popular mod back in the day when Savages ruled the dirt. Those S25 engines were terds as far as power but easy to tune for the beginner and have fun. Reverse is handy if you bash in tight areas where you need to back up out of obsticles, but the reverse design weakens the overall drivetrain integrity and it might be an issue with .30+ size performance engines. If your in a bind and need parts PM me I have a ton of parts and can hook you up as a favor.
