Photos!!!I fried my hand on my pipe, that felt great.
Trip..
Between the marks on the side of the building and the holes in the screen (Or missing screen) Kiss your deposit good by. :lol:I used the side of my brick building, it took a little while but it worked, sortof.
I was going to swap them, but I don't have a puller to remove the clutch boss. I will go pick up a puller in a few days and swap the housings around. Trip..
hi trip hows the gp290 going ive sort of got the same engine but ive got zenoah bottom end with stuffed 28mm crank zero drag seals with a zenoah 36mm piston ddm gp290 esp head its the macined one its not ported it can with a stock gasket which just destroyed its self it blew out big time so i put a 0.15 copper gasket in the standard one never had much squish but the copper one is ok it now has a ton of compresion im using a wt771 carb with alloy inlet malossi boost bottle and a victory pipe its only had 5/6 tanks run in it and its starting to losen up nice now and its hot more than enough grunt for what i need im going to get it apart when its had 10/15 tanks to check the ring and change i think
