Good job brother I was just coming here to spread the good newsFound this on Instagram.
This will be fun!
It must use the v2 35 cylinder with a blocker.Good job brother I was just coming here to spread the good news
Should be less than a 40gt so probably $850 950 rangeHow much you guys reckon these will sell for?
Yes, but it needs to start somwhere.I'd be more impressed when someone stops using piston port top ends with epoxied intakes for reed bottom ends. Would be nice to see a sleeved cylinder and a heat sink head like a nitro... this is just kicking the stone down the road.
I haven't fallen for the hype on any of them. The guys with 34 reeds and Taylor 35s get maybe 2-3 lengths on me off the line with my stock 32cc. For the extra $$$ I don't see it being enough. If I was a smoother driver I'd beat them all with the stock 32cc. Lap traffic is a real thing!My point is what more is there to gain from another piston port head on a reed case? Obr claims 9.4hp on a piston port on a reed case and we know that isn't possible, so my questioj is what more is there to gain other than "new" looks?
It's could be made of a lot of metals, but realistically some form of iron would be just fine. We sleved a lot of jugs and blocks at the machine shop. Most the time we got the material from LA Sleeve, For parent bore applications. They used to do a lot of older 2 stroke engines, but the port matching was a bear. Was easier to send them out to a specialty company. Few times if they had steel sleeves we would over board them then send out and get them hard chromed. I'd assume nikasil could be an option as well, but I'd assume it would be one of the more expensive options on small batches like we did.Like Sean said it most likely comes down to moq to get price right and there's just not enough of us.... If I'm not mistaken the sleeves have a complicated metallurgy to them?
so what one is better reed or the other one?
