tizdaz
Hi guys,
i have a new DBXL 2.0 (zen 32) an olimat unsilenced pipe, 10k steel clutch & I'm running Badlands mx43's.
Mid-top end is perfect, low end is a different story, I have it tuned, runs with no issued except for this low end power. Even on loose surface, the wheels barely spin! Climbing steep-ish hills it also seems to struggle until rpm gets high then its as if a powerband kicks in and power is what id expect, but up until then, it runs like my FG used to years ago before I had a tuned pipe on it!!
I cant compare it to stock as the pipe/clutch etc was fitted from brand new. The clutch is an 9500rpm steel one from taylor RC, this one: https://www.taylorrc.co.uk/product-page/fs-steel-clutch-with-ddm-9500rpm .
Ive also lowered the gearing to help with bottom end but didn't make much difference, and i was running MadMax Land G Rippers which are a very big tire, so thinking that might be the issue, as said above, i bought some MX43's and changed gearing. but nope! still the same
any ideas?
I've messaged the place i bought pipe from asking if its a mid-top end pipe rather than low end. But even so, the low end performance is poor!
any help much appreciated!
![20230402_182422_resized[3206].jpg 20230402_182422_resized[3206].jpg](https://www.largescaleforums.com/data/attachments/82/82775-c9d3c11a97ab71ddba2061a0fc2a7a2c.jpg?hash=-9sAZwdYK-)
Here's what spark plug looks like, which seems to be all good so the mixture is ok, like i say apart from this issue the engine runs well with no hiccups etc..
also does this look normal? it looks like the clutch shows are not making 100% contact?Hi guys,
I cant compare it to stock as the pipe was fitted from brand new.
Ive also lowered the gearing to help with bottom end but didn't make much difference, and i was running MadMax Land G Rippers which are a very big tire, so thinking that might be the issue, as said above, i bought some MX43's and changed gearing. but nope! still the sameany ideas?
