2 year old thread, guess that's not the worst resurrection weve seen. ?
Have a new 320 Cc from Rovan, not CY, and i fotunately opened it before running: Piston was installed wrong! All junctions are sharp and no Finish has been done. Just raw from machining. The crank turns wery strong, the bearings must be low quality. Washed the crankcase with petrol and found metall snippets in it. The bearing in the crank has lots of play, 1-2 mm. No whashers to avoid play around. The cylinder Looks not well coated and it will surely not last long, until it will geht friction with the piston.2 year old thread, guess that's not the worst resurrection weve seen. ?
I have a 36cc ROVAN 5t so when it works it's awesome BUT that's when it works. Every other day it's something different. First no start then it will run for a week then again no start. It eats sparkplugs. It's just not worth it go to Ddm and get a ZenaohHi all,
I'm thinking about trying the new Rovan 36cc engine. Is anyone here running this engine? If so how well does it perform and how easy is it to start?
Thanks in advance
Hyperdad
Yep, ditch it and get a zenoah.I have a 36cc ROVAN 5t so when it works it's awesome BUT that's when it works. Every other day it's something different. First no start then it will run for a week then again no start. It eats sparkplugs. It's just not worth it go to Ddm and get a Zenaoh
Hi, don't, they are not the best, they have 2 piston rings, in my opinion get the 32cc or 29cc zenoah, same house power ,kind of same price, much better quality, but i do recommend the rovan 45 cc..i love that engine i have a few and they are fast with a good pipeHi all,
Thanks in advance
Hyperdad
