My new VEKTA.5E ULTRA from down under Australia!
Marko R1
Here is my VEKTA.5E ULTRA with quite a few upgrades...also swapped out the supplied Leopard 530kv with the BIG BLOCK Hobbywing 560kv & now runs cool as a cucumber after running 74MPH :)
This motor is no joke as I can easily gear the hell out of it but 74MPH is plenty enough!
Are u on FB? I may know who you are :)
You can actually squeeze on a 21t without any mods to the motor plate 💪 and the mesh is spot on 👌
Temps were below 35C on motor & esc - it runs cool as a cucumber 😁
OK thank you so much one last question going to upgrade my vesla to hobbywing 650kv what size pinion are you running mine is stock 17-57 will a bigger pinion work on stock motor mount thank yiu
Hi mate - my Vesla stock has the 650kv with 18t & as per Kraken website they have 20t as an option so theoretically you could go as big as 20t 👍
Thank you I got mine 23 months ago then they upgraded to 12s I'll up grade motor esc 12s battery trays and harden diff gears
I would also look at getting the dual fans for the motor via Kraken - I have a friend with 650kv (12s) & he says that the motor still gets to 190F hence fans are good insurance
