Marko R1
Both your cars are monstersHere is my VEKTA.5E ULTRA with quite a few upgrades...also swapped out the supplied Leopard 530kv with the BIG BLOCK Hobbywing 560kv & now runs cool as a cucumber after running 74MPH
This motor is no joke as I can easily gear the hell out of it but 74MPH is plenty enough!
I have the ultra I also changed to motor to hobbywing 560kv I run a 20t pinion and it's a runnerThese Krakens are very different to my 5T & 5B, yeah they are solid monsters that’s for sure
If you don't mind what trmps are you getting on your runsAre u on FB? I may know who you are
You can actually squeeze on a 21t without any mods to the motor plate and the mesh is spot on
OK thank you so much one last question going to upgrade my vesla to hobbywing 650kv what size pinion are you running mine is stock 17-57 will a bigger pinion work on stock motor mount thank yiuTemps were below 35C on motor & esc - it runs cool as a cucumber
I haven't either but I have seen people switching to these.I never had a problem with the supplied V2 driveshaft but I did upgrade to the V3 as it has metal retainer clips to hold the pins in
