Motor spacer issue with baja .
Barber213
Good morning . I’m currently upgrading my king motors baja . I was told to upgrade the motor . But after installing the new motor . I realized the motor is slightly off center from the motor mount holes . Can anyone let me know if there’s a spacer that I can purchase to resolve this issue . Im using a nut as a temporary spacer . I included pics .
its a normal sort of thing from engine to engine with the baja fella, different clutch carriers from zenoah and cy or aftermarket sometimes you need a smaller spacer,
just make yerself a spacer , find a spacer thats the right size,
line everything up first, engine mounts, gear plate etc then measure what size spacer you need, (y),
edit; its normally only a matter of 1mm or so difference in the spacer needed,
some people just crank it down and force fit everything, thats when issues start with binding parts etc (y)
I used a nut that works perfect . I did the measurement . It would have to be 15.4 mm to be the exact height . Trying to see if I can cut this old brake mount spacer to size or find a spacer on Amazon .
Agree with derby. Buy the turtle clutch housing. It adds bling and is much stronger
Ah! I'm building a baja 5b sbk as we speak... juuuust encountered the same problem mounting a Zenoah G320RC. Was scratching my head.
The HPI kit comes with two options in sizes of spacers.
The part # is 102164b for the shorter one if anyone is after the oem one.
I'm building an SBK now too, let us know how your build goes
