horatio
Active Member
- 9
Wow! It's in perfect condition!Been cleaning up the Baja, waiting on parts at the moment
I have the SS pipe but it's too obnoxious for where I can run the carI would bin that exhaust and get a nice pipe on it .
Should let it breathe a bit better for sure.
This is the one:is this it:
https://www.rcmodelz.co.uk/rovan-nylon-sym-steer-push-pull-steering-kit.html
is this servo any good?
https://www.rcmodelz.co.uk/30dn-70kg-hv-digital-servo.html
Yes they are a bit spendy. My Protek throttle/brake servo retail at £169.Been looking at those, half the cost of the car....
Yeah ! mine kept doing that too .as above fella, fid brakes are good
also as above i've had gtb brakes as well, in fact i still have em, but a pain to bleed and they always seem to get air bubbles back in the lines as well,
shock oil the stock baja shocks always came with mineral based oil, thats all i've ever used in stock baja shocks cos was always unsure whether silicon oil would make the o rings swell or not, and 35wt all round is a good place to start,
i-rc shocks use silicon oil from the get go though,
The push/pull setup will be a significant improvement either way. The nylon one has more flex. Both look really nice to be fair. I went with the alloy one because my rig already had enough black parts.Std length arms - the extended arms were over budget.
The steering setup was the only one they had, only £34 so if it's no good I I can replace, my thoughts are that I will keep the std HPI steering servo for the moment, replace the brake/throttle servo for a 40kg decent one and see how I like the car.
Pics once the parts arrive, will fit on Friday
