Time to tear this truck down and rebuild!
Lots of good choices in that pile of goodies!!!!! Absolutely use the v3-4 steering, eliminating all the extra links makes a big difference. Watch Owen on primal install for tips plus you eliminating the mounts on axel makes getting to shocks much better depending on where you mount them or go with dual shocks
@Mick Mars You were not kidding when you said some of these bolts are near impossible to remove... I used a torch, lots of elbow grease, and had to hammer a t10 torque bit into one of them. The front axle was extremely hard to got apart. The diff screws backed out, fluid escaped and seeped into the screw holes. This made those screws holding the axle together very tough to get out.
The diff is looking rough, I'm nervous to see what the inside looks like.
The diff screws were grinding the axle housing
You are very fortunate that you caught it before it destroyed the axel housing. I've gotten away with a mild cleanup with a chain saw file in the bearing bores and a small 90 degree right angle grinder. That's a very familiar scene to me. Brake clean everywhere and inspection. If there available the v4 diiffs are way better but still need disassemble and fluid check. I use 1 million diff oil in everything. Just warm it with a heat gun or hair dryer to get it flow in. That all looks reusable but replace the screw on diff. Also the v4 bolt kit from primal is great for spares. I have replaced every bolt with v4 including the servo mounts to axel with the socket heads instead of flat head or panheads. There's only a couple spots where the socket heads don't fit.
Absolutely, sometimes I think the building is more fun than running!!! Yet at the same time when the motor fires up and my heart beats faster , especially with the Taylor 50 truck, it's a reminder of how blessed we are to have these wonderful things.
It kinda stinks that we spend large amounts of money on our rc products and have to take them apart brand new and check everything. The new 5t 3.0 has rear diff issue out the box. Even though it's a standard for me on everything I buy. One of my pet peavs is to almost always, depending on my stock, to order a bearing or bolt kit from primal. I usually use a pre paid card and pick up odds and ends like brake spring kits etc to use up card. Been times primal been out of stock for 6+ months on small and big stuff. Or when they have a sale . Looks good so far . I've been able to clean the housings where the diff screws crashed into it with a cut down disc for small air grinder. Dremmel comes in handy too. Keep at it with the updates.
Finally getting back to it. The previous owner though the servo brake servo was bad, so he replaced it with the 130kg servo... hmmm... at some point I may but one more of those and swap both the 130kg servos to the front axle.
Critical area now.... did you get the steel upgrade servo saver setup. I don't know if that is stock on v3-4 . The original was aluminum and galled/bound easily. Your clearly skilled at this but make sure you time time the steering servos....take your time and be careful with the steering. Even the slightest imbalance will burn servos. There is plenty of adjustments to get a no buzzing servos anywhere in travel, both electrical and mechanical.
I completely forgot about getting the steel upgraded steering post. I'll get one ordered. I plan on connecting all the wires and getting the servos aligned perfectly before I get the axle put back on.
I am not too thrilled with the v4 steering setup I got shipped to me. The included screws were too short and one of the heim joints were completely missing. Luckily I have plenty of spare parts on hand. I also added longer screws on the steering knuckles so I could put a lock nut on.1192.webp1194.webp
I did the same setup. I also ended up nibbling a bit of the ends by the jamnuts to clear that rims at full turn even after adjusting endpoints. I also removed the 2 top pieces off the top of axel to make bottom shock bolt access easier if you run dual shocks. I also set it up with a tiny bit of toe out to help with steering. The truck can literally turn on a dime in grass or lose dirt but not on asphalt where it tends to push. Keep the updates coming!!!!
Front axle restoration complete! The servos are perfectly aligned with no buzzing and not getting warm. Moving on to the transmission and crossing my fingers. Going to upgrade the reverse setup to v4 while I have that apart.
I'll save that for next weekend. It looks like it will take a bit of time to get that transmission off the truck.
I have tried for over an hour to set up this reverse v2.... pain in the butt! Can't seem to get it right! Looks like I need to take it all back apart and see what is going on.
Aaah….. relax.
You will get it figured out.
I have one to install too. I’ll follow your lead.
Enjoy the process.
Hard to tell from the pictures, but it keeps getting stuck in reverse. When it goes in reverse something catches and the springs cannot push it back into drive. It's either a rough spot on the 2 pins or on the yolk. Looks like I'm taking it all back apart again.
Look for basics.... clean everything out. Test with no grease to eliminate it. Personally l don't go heavy on grease and use nothing but a light coat of Lucas red and tacky...the best in my opinion. I've seen guys pack stuff full and all it does does is retain heat and keeps parts from having room to expand and contract... .Also considered that everything needs that little moment/movement to fully engage if this makes sense. Finally if you have to, give the surfaces that are contact/ friction areas a little polish with soft scrubber or fine steel wool. We ain't building rocket ships so go with the keep it simple rule.
