- Flintshire,North Wales
Hiya folks
I have been recently been on a quest for a virtually indestructible FG MT. So In hind site I have collected all the parts I should need for an MT that wont fail!
So far the parts are as follows.
Engine.
CY bottom end and a Zen head (big bore)
0.7mm ring
WT 813 carb
Red neck pre-filter
Alloy intake manifold
DDM billet alloy filter
Teflon gaskets
Iridium plug
ceramic bearings
Alloy engine mounts
TWO speed box
Alloy gear mounts
lightened clutch bell
8000RPM clutch spring
DDM chrome engine covers and pull start(to add a bit of bling)
Body.
Standard FG MT body with bumper.
Chassis and drive train.
Standard chassis
Alloy diff mounts
Alloy LSD
Alloy rear arms
Alloy shock tower
Teflon shielded Race bearings
Up front.
Alloy tower
Alloy posts
Alloy brace
Alloy top arms (waiting on a set of bottom arms folks)
Allot hubs
Alloy steering arms
Alloy A+B bulk heads
Alloy servo tray
Alloy servo saver
Hydro brakes
Electrics
Multiplex steering or dual HiTec set-up
Throttle Hitec 180Oz.
Spektrum DX3s
Alloy servo arm/s
Tyres are as standard pattern but have been cut(don't do it if you don't have enough money to replace them,you can mess up!)
I think that's about it.I will be showing build pictures and run vids too.
Hopefully you will give me your thoughts and comments.
Thanks for looking.
James.
Engine.
0.7mm ring
WT 813 carb
Red neck pre-filter
Teflon gaskets
Iridium plug
ceramic bearings
Alloy engine mounts
TWO speed box
Alloy gear mounts
Body.
Standard chassis
Alloy diff mounts
Alloy LSD
Alloy rear arms
Alloy shock tower
Up front.
Alloy tower
Alloy posts
Alloy brace
Allot hubs
Alloy steering arms
Alloy servo tray
Alloy servo saver
Hydro brakes
Electrics
Spektrum DX3s
Alloy servo arm/s
Thanks for looking.
James.
