well i brought one of these from whh
as some times when cornering i notice she slows down when it sucks a bit of water spray from the right vent of the hatch cover.
ive also brought a 7016/3 cheap aluminium prop from whh to try out, as i like the 7016/2 steve lent me to try out, sofar ive only used the 7016/2 once but to me it made a big improment, so i would like to try a 3 blade in the same diamiter and pitch to see how that goes befor i jump in and by a good 7016 of my own.
im working now so i also brought the race version bonzi pipe with 1 inch band so i can unscrew my bonzi quiet and convert it to a 1 inch band pipe, that bonzi call it there race pipe so ill see how that goes.
my replacement rudder isnt here yet i was hopping it got here for the weekend as there weather has been great no wind and pritty warm in the 30 degree range.
last time i used the 7016/2 i didnt have my tiny tach on as it was drying out so im keen to try it with the tach and see what revs im getting and compare the speed and rpm with the stock prop and the 7016/3 to see witch way i can go, then later try the abc 3 blade.
ive also been thinking about zero drag crank seals, i would not dare use them for off road rc use but since the boat isnt running in dirt and sand im thinkig about it.
i might be doign this back wards but if i can get the most speed and rpm out of the motor as i can with set up and so on, befor i tune it, it should go well, but its been temptiong just the lean it out and see what she will do, i quess im trying to look after this motor and get a long run out of it as its only 4.5 hours old.
so im hopping the new rudder gets here befor next weekend so i can have a run and get some rpm readings on stevs prop and then see witch way i can go.
im not sure how long whh order will take as my last order took a fair while just to hear any thing back they must be realy bussy.
does any one know if the prop rpm drops a bit runnign 3 blade props over 2 blade props ? you would think so.
as one 3 blade prop i was recomended has a diamiter of 72 but a pitch of a 100mm i know in 2 blades that just makes my motor rev its guts out.
