2stroker Baja
I've been slacking on this build so here's a couple updates. I figured Doug's 65 pulled close to the same weight with the cage and alloy bits on his build very nicely. So this 80 supreme should definitely be a bit more aggressive. John at Detroit hooked me up with a sweet ceramic coated TG ultimate pipe. I added a alloy symmetrical steering top plate and battery tray, still need a throttle/brake servo, linkage and few small odds and ends, but should be ready to roost in a couple weeks. Even though they look decent the genesis wheels are getting replaced with brps. Also I still haven't decided on a wing yet 😅
I keep finding bits to add here and there😵‍💫🤪 Threw a HPI wing on and hated it...wrappd a little carbon vinyl to match and now i'm staring to tolerate it😂 Picked up a set of HPI stone guards that I'm undecided on installing, but did install the side cage supports. Also added much needed Red IRC UHD springs all the way around and Galante limit straps, a set of BRP knobbies, 27/47 Blackbone gears, bonehead wheelie bar, afgrc throttle/brake servo, hilantronics 5k for the symmetrical steering and today ordered the taylor brp inserts and a new ez pull start. I keep saying I should be ripping by this weekend. 💪😁👍
Quit adding poop already and run it 🤣. If I can run my 96 you can run this
First Run, needs a good tune and need to increase my rear springs for more traction, im running 27/47 gears on BRP knobbies. Grass is green freshcut and growing like crazy so it's a bit slick. I may need to drop gears and run the spikes, but here's the first go until the header studs became loose and shite got ugly loud😂
Sorry for the poor view, I'll figure out something better for videoing
