5ive t with engine Alx Super 71 Performante
Termy82
After many test and bashing session I made a review of my new building .
These are photo of my car :
I mounted a big bore engine ALX SUPER 71 PERFORMANTE with gear ratio 30/44
I think this is the maximum safe power engine that can mount on losi 5ive t platform, I ran for 13 liters of mix without breakage
The engine it’s very powerful and it’s based on a new racing technology malossi mhr flanged 47.6 mm with 7 intake ports
The piston pin rod it’s a 13 mm very big to don’t stress much the ball bearing . The crankshaft is very solid and resistant. The head have a very beautiful multi fin system to cooling the engine .
This is a little bashing session it’s a animal power engine with 21 horsepower
A special tanks to Alx Engine for the great customer support to building this monster
Little mistake 7 intake ports
I use irc center diff cups
Irc center to front shaft
Flm drivecups flm driveshaft
And pathdad center to rear diff
Helical crown and pinion front and rear
What is a helical crown and pinion front and rear ?? Send me the parts on Facebook messenger I'll ask for em !
Those tires probably the only thing saving your drivetrain
What do you mean ? Because he doesn't get good traction aka sparing the hard work it would otherwise put on the drivetrain ? Also noticed he don't use a locker so im assuming if I go that route I would be fortunate and could run aswell ?
Walk Off No GIF by Jarritos
They spin alot, not much for traction, they hook snap goes the pins and dogbones. Hell my Dawson 46 snaps irc dogbones and factory losi dogbones. Ate pins like butter. Maybe flm is stronger but I doubt it
These are photo of my drive pin and cup that have 30 liters of mix with bzm 28.5 and 13 liter of mix with 71 performante
Never change pin…
There are other many people that use big bore on losi 5ive t without problem how
Garrets Khaos that use Alx super 85 without breakage from 2 years
https://m.facebook.com/story.php?st...1CTsLekm56ZCCkQr7aYm7ZoTHl&id=100066595053099
Or John could ridge that use 71 performante in losi 5ive t from 2020 without problem
