5t 2.0 shocks are leaking
Geez. How did you manage that? I had mine cartwheel about 5 times at about 40mph and have yet to break something..looks like you may want to get limiting straps
Not sure. I added the orange springs and 50w oil when the car was new. Didn't like the stock damping was little too soft.
I might add little bump stops like my dbxle. 2.0
I do have droop screws but limiting straps will prevent over extending and bending shafts. This could of been caused by the thicker oil and being plastic well this happens.
Well found the problem. One of the o rings is larger and fatter than the correct one. Now time to hit the store to find something like the original.
maybe someone confused a diff o ring for the shock o ring....i saved my old ones because when I took my diffs apart I saw the same o rings in there...didnt really check sizes but same thickness and color in there
