HPI makes a kit, is it a direct replacement or is there one made specifically for the FG.
http://store.largescalerc.com/hpi15448.html
Thanks for your input.
if your shoes are not bad just get the spring set. its only like $9.
Thanks, can I simply install the red spring?
sure can .. or bite the bullet and by a adjustable clutch 3 or 4 shoe clutch DDM has a good amount there
Thats some good advice right there, the elcon 4 shoe clutch is the best "it's probably the only Elcon item you can instal without changing half the car also".
How hard are they to set up, do you have to remove the clutch bell every time you need to adjust or can they be adjusted externally.
clubin .. you can sleep when your dead !
