its usually normal build up of weepage and dirt mate, unless you have a big leak that would be pretty obvious though,Is there anyone that can help figure out why my carb on my dbxl 2.0 has black oily stuff on it
I only been running mine in a parking lot. No dirt or anything. Unless I have a leakits usually normal build up of weepage and dirt mate, unless you have a big leak that would be pretty obvious though,
the dirtier the place you run the more you will notice it,
some of us wont really notice it cos we keep the carbs and cars really clean,
i try and give my carb a blast off with brake cleaner every so often, ( only do that when everythings cool and in a well ventilated area though ),
Hey Spents, why brake cleaner and not carb cleaner?its usually normal build up of weepage and dirt mate, unless you have a big leak that would be pretty obvious though,
brake cleaners much less harsh and wont affect any rubber lance,Hey Spents, why brake cleaner and not carb cleaner?
post a picture mate,I only been running mine in a parking lot. No dirt or anything. Unless I have a leak
I cleaned the carb and have a different air filter. I will see what happensNon chlorinated brake clean is what spents is talking about. It can still be pretty harsh, but normally not as bad at regular brake clean or carb cleaner.
If your talking about in the thought of the carb then it's dirt from running it. The air filters pretty well suck on the dbxl platform so it's wouldn't hurt to get an aftermarket one.
What oil do you use on your air filter?Make sure you oil it.
^^post a picture mate,
plus how long you been running the car without cleaning the carb off etc,
and theres still gonna be dust in a parking lot![]()
I use motul, on my foam filters. Just vecause in cheap and it was on sale that day. Many options out there, just make sure it's for a foam filter.What oil do you use on your air filter?
