Clutch problems
Andrew
Australia.
Can someone tell me I have a dbxl with a g 32 zenoth motor installed today. after 5 min of running it seemed to be slipping and made a noise . Is it the clutch cy clutch red spring .Or I think it's spinning on the crankshaft is this possible any one had this before ( the clutch bell was hot also I don't think the losi dbxl has a slipper clutch ? But I'm not sure. can't see one
dougstar
KZN South Africa
Hi andrew
I would open it up could be the clutch spring , id did not think it could go coz the look pretty tough but they do go south. best way to find the issue is to open and look. How you finding the 32? My rig has a stock G320R cant complain she flys:D(y)
Andrew
Australia.
G'day dougsr how's things mate the motor is mad brother this is what it needed just me mate hopeless with no knowledge yet so it's sucks . I red loctite on The clutch plate on the original change over from the 23 zenoth and it started slipping after 5 min then I tried removing the clutch plate and snapped the screw in crankshaft. Then put a new crankshaft in and started again. The motor is tuff but I can't workout what is going on with the clutch plate do thay normally slip or do I need better clutch.
G'day crew. just thought I'd let you
Know. I have booked in for my first race this Sunday ? Hope the g32 dbxl can handle
dougstar
KZN South Africa
When i put mine together and put the cy clutch plate in i had to really tighten the blot down. I first had it all togeher it sliped in my hand. So thats when i gave it some real welly(y) and its been fine
Phill2
Yeppoon QLD Aus
Hi Andrew
Where are you racing?
Andrew
Australia.
Hi andrew
just had a look yep you were right the screw holding the small gear on housing had moved? The bearing was out a bit so just put back together and ran seemed ok Thanks mate Andrew
Andrew
Australia.
G'day Phil hope all is well the tracks in Hallam, Melbourne Australia just going down at 730 I'm really not sure on process yet but will see will let you know thay might say no I joined last week but haven't been there yet. Now the 32 seems flooded or mixture screw is wrong I had trouble keeping it idiling . Then it wouldn't start and I touched the mixing screw on the right of the two mixing screws now I'm stuffed how many turns on 11somethig Darby cheers mate. Is it still raining up qld ( I never seen rain like that ever and I'm 49 good to hear from you regards Andrew. I'm just going out to retry starting this problem child mybe send down some matches
Phill2
Yeppoon QLD Aus
Bit far for me to go watch so good luck with it.
Rain stopped last weekend.
Hopefully you'll have better weather on your next visit.
dougstar
KZN South Africa
check out the pic
so 1 full turn = 360 degrees
3/8 of a turn = look at the pic
circle divided into 8
coz you are loosening the screw youll be going anti clockwise 7/8 is the last line before your at the top again
Andrew
Australia.
check out the pic
Thanks Doug will try now makes sense I've been doin 1 turn then almost a full one again backing it off a bit
dougstar
KZN South Africa
start by closing the screw all the way but don't tighten just till it stops. take note of were the screw stops work your way from there.
let us know how you get on(y)
