- Crafers South Australia
Holly cow Z? bet you gonna be shitting. Baby seals getting this part done ....
Come this far don't let it slow you down??
My suggestion of removing some material from the piston skirt was a suggestion based upon the fact you might only have to remove a small amount at the 4 corners of the skirt. You won't be altering the port timing in this particular case. I have no idea to what extent you need to remove metal, all's I was trying to do is get you to think in both directions. Remember this quote with respect to "grinding" engine port work : "It's WAY easier to loose 2 hp , than gain 1 hp with a grinder".
I'll cut the case, I don't like the idea of messing with the piston for some reason.So me personally I'd still cut the case. But I think you'll be ok taking that off the piston. Or a combination of the two. Cut the case on the intake side as it looks like it's just going to be a little nub to remove and cut the piston on the exhaust side. If you go the piston rout cut a radius not a sharp 90* corner. Sharp corners can be stress risers and fatigue the metal.
Yes it has 6 levels of speedIf your die grinder has multi speed capability , thats a big advantage. My industrial pencil grinders have a 15,000 rpm and when a sharp carbide round cutting tool grabs soft aluminum it ends up looking like a cratered mine field . Now i have a precision Dremel (adjustable RPM) tool and its much easier to control with far less risk of a "runaway" .than my pnumatic tool.
Yep.?So you makin progress ???
Yeah it's already done and I've experienced that, soooo annoying and left some light tracks on the red ano so very noticeable ?? my anodizing already looks like poop. So that's why I'm seriously considering just de anodizing the case and polishing it, like thisI use burrs quite a bit making jewllery and what i found was the worst thing is when the burr bights real hard pull your hand away from the work area? leaves track like sand paddle tiers??? so go easy don't rush it coz you cant put material back on??
Lmao. Here ya go. I may have over done it on the intake side, but transfer sides (were the rear of the piston skirt was hitting) side is enough, the least I could remove actually.Well come on post some pics of the hack job??
