- Maryland, USA ??
Awesome you got her started. Can't wait for the video.
So what do you suggest with the starterI would be very careful smacking around a hard m8 crank end!!! , snap off alot easier than you think. They are strong but not in the way you are using it.
zee , seen a guy take another set of the shorter upper rear shock springs and another set of that slider perch and he clipped the coils down to put on top of the short springs already on there [three spring stack ]get proper ride height with a big motor in chassis
Yep!!! It's badass. You probably know the feeling but when I I first got it to sort of start. I had so much energy, like jumping around screaming happy type of energy!! Such a good feeling.Congrats Z! At least you know shell run on high test.
It's an amazing feeling!!Nothing like like getting something to run you built yourself!
It's like getting your first hot dog into your bun! ?????Like Madonna ,touched for the very first time?.....LOL
There's a pawl thingy like this that screws on the crank I believeView attachment 52725 but that's for a pull start. I'm using a drill start ATM.
Can I get maybe a example? I want to see what kind of pilot shaft that u used so I can replicate that .The other option is to find some kind of pilot shaft that will screw on ,an find a O-way bearing that is hexed
for a socket ,I use that concept on one of my nitro's that I don't have a pull rope starter for!
They make different types of those ,the other type ,they swing out on the starter it self on to some type
of cog!
So something along the lines of this?I don't have nothing on hand to take a pic of ,but it is a female thread at one end ,an smooth stud at the other!......LOL
So something along the lines of this? View attachment 52726
If so, question, how do you keep the one way bearing from sliding off? Or do you remove the bearing after start? Or does this attach to the drill? I'm confused. A picture would really really help of both the engine side and the drill side
Yeah I'd just like a pic so I can upscale. So the shaft with female threads goes on the crank end, and the OWB goes into the socket right?It looks something like that ,my O-way usually just falls onto the ground ,but I thought about JB welding it in to
the socket!
I can show pics of the o-way that I use ,an the shaft on the engine ,but you would need a bigger shaft An o-way unit ,
there maybe even one on market already!
So starter cup that would connect to the flywheel rather than the crank end right?a machined drive cup larger than crank to bolt up to rotor to take load off crank end and spread the load out. a larger starter cup will also turn over easier, Maybe a large scale open class gas boat starter that can engage the cup on rotor. 12vt , field ready ?
Will have one when I get that starter thingy sorted. I think corn juice might be on to something on his idea. You will get to hear it, don't worry ?? I'll make a vid when I can get it to idle for more than 2 secondsWell done Z ?? were is the start vid????
