- Maryland, USA ??
1. Did you charge the batteries?
2. Usually around 1/4 throttle, depending on the engine/clutch
Are you sure they are charged? Not sure which charger you have but are you sure its charged?
Yes every RTR may be different with engines that come with it. I know 5ive T 2.0 is a 32 but the older was a 26 I believe. Not sure what came in the dbxl.
A killer bee will remotely shut the truck down with low battery power, loss of signal, or press of a button. It is a must with any gas 5th scale. www.davesmotors.com is you place to order. I believe they run about $50 or so.this truck is bone stock, just ran for first time today, haven’t even completed break in
endpoints?Check your endpoints on each
i’m not sure what that means?And get ready for the my killer bee don't work because I have a spectrum.... disable AVC.... whack yourself off..... buy a futaba....
this will work with my bone stock setup?A killer bee will remotely shut the truck down with low battery power, loss of signal, or press of a button. It is a must with any gas 5th scale. www.davesmotors.com is you place to order. I believe they run about $50 or so.
